How Do You Calculate the Mass of Object A?
  • Thread starter Thread starter oo7 - 2oo
The discussion centers around a challenge to calculate the mass of an object labeled A, with the poster indicating they will reveal the answer after a day. The poster emphasizes that this is not a homework assignment, inviting others to participate. However, the thread was ultimately closed due to forum rules prohibiting "Quiz Question" type posts in the Homework Help section. The focus on the calculation sparked engagement, but the forum's guidelines were enforced. The interaction highlights the balance between community challenges and adherence to forum policies.
oo7 - 2oo
Hi everyone,
Calculate the mass of A if you can ?
one day to solve it then I will post the answer !
* it is not a homework !
good luck
I can! But can you?
yes I can .. but it is for you
oo7 - 2oo said:
Hi everyone,
good luck
We don't allow "Quiz Question" type posts in the Homework Help forums, for obvious reasons.
Thread closed.
