What is the mass of water ejected per unit time from the nozzle in a toy rocket?
  • Thread starter Thread starter gaobo9109
    Momentum Rocket
The mass of water ejected per unit time from a toy rocket's nozzle is calculated using the formula πr²pv, where p represents the water density, r is the nozzle radius, and v is the velocity of the water relative to the nozzle. This relationship derives from the geometric principles of fluid dynamics, specifically the volume flow rate, which is determined by the cross-sectional area of the nozzle and the velocity of the water. Understanding this concept is crucial for accurately predicting the performance of toy rockets.
  • Fluid dynamics principles
  • Basic geometry of circles
  • Understanding of density and mass calculations
  • Knowledge of velocity and flow rate concepts
  • Study fluid dynamics equations related to flow rate
  • Explore the relationship between pressure and velocity in fluid systems
  • Learn about the effects of nozzle design on fluid ejection
  • Investigate practical applications of fluid dynamics in engineering
Students in physics or engineering, hobbyists building toy rockets, and anyone interested in the principles of fluid dynamics and rocket propulsion.
gaobo9109
A toy rocket consists of a plastic bottle which is partially filled with water. The space above the water contains compressed air. At one instant during the flight of the rocket, water of density p is forced through the nozzle of radius r at speed v relative to the nozzle. Determine, in terms of p, r and v, the mass of water ejected per unit time from the nozzle
I know the answer is πr2pv. But I am not sure of exact explanation why this is the case.
its not so much about momentum but really about understanding the geometry of the problem.
You know that the water has a certain velocity, you know how far a single particle of water will travell in one second. You are also given the radius of the nozzle therefore you can easily figure out the volume of the water that leaves the bottle every second.
It will be the area of the nozzle multiplied by the distance traveled by the water in one second ( that is V=pi*R^2*v)
once you have the volume its all easy as you can use the density to get the mass. it's just the volume multiplied by the density.
  • · Replies 20 ·
11K
