What Is the Maximum Radius for a Loop So a Ball Stays on Track?
  • Thread starter Thread starter pb23me
    Ball Loop
To determine the maximum radius of a loop for a ball to stay on track, the initial speed of the ball is given as 4 m/s. The discussion emphasizes the importance of centripetal force and conservation of mechanical energy to solve the problem. Participants explore the relationship between the radius and the height at the top of the loop, noting that if the radius is too large, the normal force will drop to zero, causing the ball to fall. The final calculations lead to a radius of approximately 0.33 m, confirming that the relationship between radius and height must be accurately applied. The conversation highlights the necessity of correctly applying energy conservation principles to find the solution.
pb23me
If the initial speed of the ball just before it enters the loop is 4 m/s, what is the largest value that the radius of the loop can have if the ball is to remain in contact with the track? Assume friction is negligible.I am supposed to figure this out with work and kinetic energy equations.
Wnet= 1/2mv2f-1/2mv2i
Wg= mgyf-mgyi
I can't really figure this out with those equations. I feel like i need more info.
You need to know about centripetal force and Newton's laws. If the radius gets too big, the contact (normal) force at the top of the loop will be 0, and the ball will fall off the track. Use this knowledge of centripetal force to find the maximum R with the use of the Conservation of mechanical energy equation.
ok I've used the formula v=(rg)1/2 and came up with 1.6m. I tried to set the equations equal to each other and solve for yf but it seems like i need the final velocity at the top of the circle, but i don't know how to get that without the height...
that is the correct formula at the top of the circle when the Normal force is zero. I am not sure where or how you obtained that equation. But v is not 4m/s at the top of the circle, so the solution is incorrect.
Now use conservation of energy, using the initial mechanical energy at the bottom, and the final mechanical energy at the top. You will now have 2 equations with 2 unknowns (r and v_top), which you can solve by the method of your choice.
I used the conservation of energy equation plugged in the value 2Vf/g for Yf and solved for Vf getting 1.8 m/s. Then i went back and plugged that in and got .653m for r.
where did this come from? The equation and units are not correct.
retry using the conservation of energy equation again. Note that there is a speed at both the top and bottom of the loop. Note also that the velocity at the top is sq rt of Rg, and y_f at the top is??,
I did it again an got .65m...r is not the same as Yf r is 1/2 Yf therefore it must be multiplied by two... I don't see what I'm doing wrong..
You have already established that v_f^2 = rg (at the top of the loop) and V_i = 4 m/s (given, at the bottom of the loop). Now please write out the conservation of energy equation:
KE_i + PE_i = KE_f + PE_f
If your browser reads LaTex, that's
Now plug in the known and unknown variables for each term, noting as you said that y_f = 2r, and solve for r. Please write out each term so I can see what your error might be.
yf/2=r so 1/2vi2=gyf+1/2vf2 then 8=(5/4)*9.8*yf
yf=.65m
r=.33m
This is wrong:frown:
0.65 m is the value for what?:confused:
yf=.65m
r=.33m
This is right!:smile:
