What is the meaning of the no heat accumulation ?
  • Thread starter Thread starter ozy99
    Heat
The term "no heat accumulation" refers to a condition where the temperature of a liquid remains constant, indicating that heat is neither being added nor lost. This concept is crucial for understanding how fluids in a storage tank behave, particularly in relation to heating systems. In a scenario with no heat accumulation, the water in the tank and the pipes maintains a stable temperature, which can impact efficiency and performance. This stability can be essential for applications requiring precise temperature control. Understanding this concept helps in optimizing heating systems and ensuring consistent output.
ozy99
What is the meaning of the "no heat accumulation" ?
What is the meaning of the "no heat accumulation" ?and how it affects the fluid in the storage tank and the water being heated in the pipe inside the tank?
thanks
I would guess it means liquid is kept at constant temperature. But that's just a guess. Can you give some details about the context?
