What is the minimum pushing force required
  • Thread starter Thread starter nns91
    Force Minimum
The discussion centers around calculating the minimum pushing force required to prevent a 16 kg box from dropping while it pushes against an 88 kg box on a frictionless surface. The key equations involve static friction and normal force, where the friction force is dependent on the applied push force. Participants clarify that the friction force (FF) is equal to the product of the static friction coefficient and the push force (FP), leading to the equation FP = (m16*g)/u. After some confusion regarding the terms used, the correct approach is confirmed, and the numerical value for the required force is approximately 60 N. The conversation concludes with a participant expressing relief at having solved part of the problem correctly despite previous mistakes.
nns91
So there are 2 boxes: 1 has a mass of 16kg and the other is 88kg. There is friction between 2 boxes, the surface which box 88kg is on is frictionless. Static friction coefficient is 0.38. Box 16kg is not on the surface, it's is push against the 88kg box. What is the minimum pushing force required in order for box 16kg not drop
F=ma
So I do F=ma in the y direction which is Fs - mg=0 to find Fs. Then I do in the x direction F-Fn= 0. From Fs I can get Fn by dividing Fs by 0.38.
Did I solve the problem right ?
Hi
It's in the middle of the night for me and I've got high fever but I think you made one single mistake. You should not divide Fs by 0.38 but rather multiply them.
Think of it this way. If you divide Fs by the friction coefficient and the friction coefficient --> 0 that would imply the friction force would --> infinity, and that dos not seem right... :wink:
Hope this helps!
Cheers
But Fs = Fn * coefficient of static friction right ? so Fn =Fs[/SUB / 0.38 right ?
Hi
I might be confused by your nomenclature. I think you might have mixed up Fs and Fn, though it might be me reading the problem or your solution wrong as well. Anyway, here's how I would solve the problem:
Known:
Mass m1 = 16 kg
COF u = 0.38
acc. g = 9.82 m/s2
Find the friction force FF
Equations
F = mg [1]
u = FF/FN [2]
My calculations:
Force normal to the plane, FN, is found using [1] (FN=m1*g) [3]
[2] is rewritten as FF=u*FN [4]
Using [3] in [4] yields FF=u*m1*g
This gives a numerical value of roughly 60 N
Questions, comments?
Cheers!
probably I confused you guys.
The problem is not like that.
The 16 kg is on the left side of the 88kg and kinda pushed against the 88kg but in the air, 16kg box is not on the frictionless surface. We need to find the min F pushing the 16kg box against the other in order for the 16kg not drop. Get it ??
I see...
Now I understand the problem and your solution. And now I agree with you and your solution. Sorry for my confusion.
Just for clarification:
The friction force, FF, is linearly dependent on the applied force,FP (P for Push), on the 16kg-box:
FF= u*FP [1]
FN=m16*g [2]
To balance the box you need top satisfy FN = FF [3]
[1] and [2] in [3] gives: m16*g = u*FP [4]
And [4] can be rewritten as FP = (m16*g)/u
Cheers!
So I did it right ?
Peace ! It was on my test. I screwed up a lot so at least I did something right.
