What is the missing value in this parallel RC circuit problem?
In the discussion about the parallel RC circuit problem, the user is struggling to find the voltage across one capacitor (Vc1), which they calculated as 31.8V at an angle of -90 degrees, while the expected answer is 5V at 0 degrees. The circuit consists of two equal capacitors and resistors connected to a 10V source at a frequency of 5kHz. A participant explains that the capacitors form a voltage divider, resulting in each capacitor receiving half of the source voltage, which is why Vc1 should be 5V. The conversation highlights the importance of understanding voltage division in parallel circuits to arrive at the correct values.
DethRose
Parallel RC Circuit Problem!
Hey I've been working on this circuit for hours and can't figure out 1 value.
This is exactly what was given to me on the page so i have no other information lol.
All that was written was:
find the values of Zt,It,I1,I2,Vc1
Ive found all the other values which are
Zt = 1.2 k angle -10.93
It = 8.28 mA angle 10.93
I1 = 8.13 mA angle 0
I2 = 1.57 mA angle 90
Vc1 i get 31.8 v angle -90 but the given answer is 5v and 0
An explanation y it is that value would be appreciated
l l l
l l l
l l l
l 550 ohm resistor .01 microFarad Capacitor
l l l
l l l
10V angle 0 l l
l l l
l 680 ohm resistor .01 microFarad Capacitor
l l l
l l l
l frequency=5KHZ l l
l l l
l l l
l----------------------l-------------------l
dumwit atleast type what you are asking properly
Well personally I would NOT call you dumbwit or any other name , but I am afraid he is correct in that I am not sure how anyone can understand your question
Ray
so where's the micky mouse cartoon i was promised1
Hi DethRose,
The capacitors are equal in size and form a simple voltage divider across the source. Regardless of the current through the capacitors, the voltage across each capacitor must logically be half of the source voltage ... 5v @ 0degrees.
V_{C1}=V_s\frac{Z_{C1}}{Z_{C1}+Z_{C2}}<br /> =V_s\frac{j\omega C1}{j\omega C1+j\omega C2}<br /> =V_s\frac{C1}{C1+C2}=V_s\frac{C1}{2C1}=\frac{V_s}{2}
(it seems your other respondents have no imagination)
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
