What Is the Period of Oscillation for Two Masses Connected by a Spring?
  • Thread starter Thread starter dowjonez
    Spring
The discussion focuses on determining the period of oscillation for two masses, m1 and m2, connected by a spring with a spring constant k. The equilibrium positions are set at x1 = 0 and x2 = 0, indicating no initial displacement. The angular frequency is influenced by both masses, and the center of mass can shift during oscillation. The stretching mode of motion is emphasized as significant for understanding the system's behavior. Resources on coupled harmonic oscillators are suggested for further exploration of the topic.
dowjonez
consider two different masses m1 and m2. They are connected together by a spring. Assuming the spring has a spring constant k. Assume the equilibrium positions are x1= 0 and x2 = 0. Find the period of oscillation.
I know the the angular frequency is a function of both masses not just one mass like a fixed system.
im really stuck on this one
Yep, this is a tricky problem because nothing is fixed and the center of mass can moved. However, at equilibrium, the spring length is given by the difference in the equilibrium positions of both masses.
Are you sure about x1 = 0 and x2 = 0?
yes that's what it says in the question. I am thinking that the x1 and x2 coordinates must be the displacement. So at time 0 neither are displaced. Also it was given that the mode of motion for the system was a stretching mode.
Since this a very important piece of physics I'm sure there is plenty on the internet.
Just goggle coupled harmonic osciallators or normal modes.
