What is the pH of a solution containing formic acid and potassium formate?
  • Thread starter Thread starter Kawrae
    Chemistry Ph
The discussion revolves around calculating the pH of a solution containing 1.00 g of formic acid and 1.00 g of potassium formate dissolved in 100.0 ml of water. Participants express confusion about whether a reaction occurs between the two substances, clarifying that potassium formate is not an acid but a salt. The correct chemical formula for potassium formate is identified as KHCO2. The focus remains on understanding how to approach the pH calculation with the given components. The thread highlights the importance of distinguishing between acids and their corresponding salts in solution chemistry.
Kawrae
1.00 g of formic acid and 1.00 g of potassium formate acid are dissolved in enough water to give 100.0 ml of solution. Calculate the pH of the solution.
>> I'm not really sure how to start this. These are two acids being mixed together... Would there be a reaction? I'm very confused on how to start this problem...
Please any help would be greatly appreciated :(
Check your question again. That should probably just be potassium formate. It's not an acid.
Oh yes you're right, I must have copied it wrong.
Okay, one more question: does anyone know the chemical formula for potassium formate?? I can't seem to find it anywhere in my book or online...
Potassium formate is KHCO2.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
