What is the possible risk of switch in its mid-way?
  • Thread starter Thread starter kenny1999
    Switch
Switches designed for AC mains typically prevent intermediate positions to avoid sparking and burning issues. A switch stuck in mid-way is generally not expected to damage the contacts, as they should remain in their last state until fully engaged. However, concerns arise when dealing with mains voltage, as faulty switches can lead to severe problems, including burning contacts. It is advisable to replace any switch that exhibits faulty behavior to ensure safety. Overall, while many switches are built to handle such issues, it’s better to err on the side of caution with electrical components.
kenny1999
Sometimes, not always though, it was my problem, not the switch is defected, I didn't press it firmly, the switch will leave in its mid-way, but it is supposed to be
either ON or OFF. What is the possible problem of doing this? Will it burn the switch or cause even more severe problem?
What kind of switch? I'm guessing you are talking about AC Mains, but what is the load?
Most switches are designed to prevent intermediate (not on, not off) positions, precisely because of the sparking and burning problem. Often, there is some spring action to hold it open or closed. So I would not worry about it.
It all depends on what the switch is connected to.
AC Mains? Did you mean there are plug holes directly near it? No...
It is a panel with only the button and everything is inside, controlling the lamp on the ceiling
switch is kind of old switch, not really too old but general and normal and nothing fancy.
These switches are built so that a halfway-stuck actuator will not supposed to affect the contacts themselves (it should remain in the previous state till that 'clearly audible click').
But: since it's about mains, I would not be satisfied with a 'not supposed'. Since it's a faulty switch anyway, please schedule a replacement.
Supposed or not, I've seen cases when this kind of fault ended with a burning contact.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
