What is the power required for the belt to maintain its velocity
The discussion revolves around calculating the power required for a conveyor belt to maintain its velocity while corn falls onto it at a rate of 1 kg/s. The initial approach suggested using kinetic energy calculations, yielding a power of 12.5W, which was deemed incorrect. The correct calculation, according to the lecturer, involves considering momentum and the inelastic collision of the corn with the belt, resulting in a power requirement of 25W. The key point is that not all work done by the belt contributes to the kinetic energy of the corn due to energy losses during the collision. Understanding the dynamics of the collision is crucial for accurately determining the power needed.
Rasmus10
Corn is falling vertically down on a conveyor belt at a constant rate of 1 kg/s. The corn instantanoulsy gets the forward speed of the belt of v = 5m/s. What is the power required for the belt to maintain its velocity.
p=mv
dp/dt=F
F*v=P
Ekin=1/2*m*v^2
Well, i thought that the simple way to solve this was to say that the belt needs to apply kinetic energy to the corns. How much? 1/2*1kg*(5m/s)^2, and that every second so the effect would be 25/2 W = 12.5W.
However, that is not the correct answer according to my lecturers soloutions. He says it is 25. Well, i can think of; from a momentum kind of view. dp/dt=v*dm/dt=F
F*v=P so 5m/s*1kg/s*5m/s = 25W. What am i missing here?
Another approach. Correct me if I am wrong, but the energy needed to accelerate an object from f.x. velocity 0m/s to 5m/s is independant of the actual acceleration (even though its a non conservative force friction that is doing the acceleration?). To say, it deosn't matter if a large force is acting in a short time or a weak force in a long time? So
Faverage*Δt=Δp. From kinematics constant acceleration: x-x0=(v+v0)/2*t <=> if x0 and v0 is 0: x=v/2*t. Ok, so we multiply by this in the first equation to get the work: Fav*Δt*v/2=Δp. So if the acceleration time of the corn was 1 second, then i get the same result as i would get with energy considerations = 12.5W. Is this totally wrong?
Thanks for your help!
You are missing the fact that not all of the work done by the belt goes into increasing the translational KE of the corn. (The corn makes an inelastic collision with the moving belt.)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
