What is the ratio of the largest slit width to the smallest?
  • Thread starter Thread starter Mitchtwitchita
    Ratio Slit Width
The discussion focuses on determining the ratio of the largest slit width to the smallest in a diffraction experiment using two slits. It is established that the slit with the first dark fringe at a smaller angle (45 degrees) is wider than the one at a larger angle (55 degrees) due to increased destructive interference. The equation used is w = λ/sin(θ), which indicates that a larger angle corresponds to a narrower slit. A calculated ratio of the slit widths is found to be approximately 1.17:1. The conversation concludes with a participant expressing gratitude for the guidance received.
Mitchtwitchita
I'm not exactly sure how to get started on this one. Can anybody help me?...Please?
Two different single slits are used in an experiment involving one source of monochromatic light. With slit 1 in place, the first dark fringe is observed at an angle of 45 degrees. With slit 2, the first dark fringe is observed at an angle of 55 degrees.
a) Which slit is widest? Why?
b) What is the ratio of the largest slit width to the smallest?
You need to show some work before we can help you. Do you know any equations to do with diffraction through a slit?
The equation I've tried was sintheta = lamda/w
For a) I plugged in an arbitrary wavelength of 720 nm and found that slit ! was larger and I figure its because the first dark fringe is observed at less of an angle than slit 2. Therefore, the number of pairs of rays that destructively interfere are increased which causes the maxima to decrease.
For b) I used the arbitrary wavelength of 720 nm and plugged it in for both cases (45 degrees and 55 degrees) which resulted in a ratio of 1.17:1
Does this sound plausible to you guys?
That gives the condition for the first minima. Since you're interested in the width, you can rewrite it as:
w = \lambda/\sin \theta
Since for angles between 0 and 90 degrees sin(theta) increases with angle, that equation should tell you that a bigger angle implies a narrower slit.
Close enough. But no need to plug in a particular value of wavelength. (Although that's perfectly OK.) Try using the equation to relate a ratio of slit widths to a ratio of sines of the angles.
Thanks Doc! You've been a big help and I think I now know what to do. Cheers!
