What is the recommended size for a neutral conductor in a 3 phase 4 wire system?
The discussion revolves around the sizing of the neutral conductor in a 3 phase 4 wire system, specifically whether it should match the size of the phase conductors or be reduced to a percentage of that size. Participants inquire about relevant standards such as IEC or NEC that dictate these requirements.
  • One participant asks whether the neutral conductor should be the same size as the phase conductor or 50% of it, specifically referencing a 300 sqmm power cable.
  • Another participant distinguishes between neutral and ground, suggesting that the neutral may not carry current in certain applications, such as motors, and recommends sizing the neutral conductor the same as the phase conductors for safety.
  • A third participant agrees with the previous point, emphasizing that in cases of uncertainty, using the same size conductor is advisable.
  • One participant notes that in low voltage (LV) distribution, unbalanced loads can complicate sizing, and mentions that some standards may require the neutral busbar to match the phase busbar size, seeking clarification on the specific clause in IEC or NEC.
  • A later reply provides a reference to an external source for further discussion on grounding, indicating additional resources may be available.
Participants express differing views on the sizing of the neutral conductor, with some advocating for it to be the same size as the phase conductors while others highlight specific conditions under which this may vary. The discussion remains unresolved regarding the exact requirements and standards applicable.
There are references to standards (IEC and NEC) that may influence sizing decisions, but specific clauses are not identified, leaving some assumptions and dependencies on definitions unresolved.
Zubair8
Hi,
Frankly, I'm new to this forum. So please do guide me if I posted wrongly.
I need some help in sizing the neutral wire. For a 3 phase 4 wire system (3Ph + N), what is the recommended size of the neutral conductor. Should it be the same as the phase conductor or should it be 50% of the phase conductor. Let say a power cable that is sized up to 300sqmm, does the neutral cable also need to be sized to 300sqmm or can it be less?
Is there any specific standard, IEC or NEC that mentioned the requirement for neutral conductor size. Appreciate if you guys can mention the IEC or NEC number.
Thanks.
Do you mean neutral or ground? There may be a difference depending on what you are running power to. When running 3 phase power to a motor for example, what you are calling 'neutral' isn't really neutral at all. It is not supposed to carry any current except in the case of a fault. It is to be grounded to the case of the motor. However, when running 208 or 240 volt power into a building the 4th conductor (combination neutral/ground) will carry some current because of lights and other 120 volt loads. You are always safest making the 4th conductor the same size as the other 3.
I agree with Averagesupernova. Use the same size conductor if in doubt.
Three phase systems may or may not have a neutral wire. A neutral wire allows the three phase system to use a higher voltage while still supporting lower voltage single phase appliances. In high voltage distribution situations it is common not to have a neutral wire as the loads can simply be connected between phases (phase-phase connection).
http://www.3phasepower.org/3phasewiring.htm"
With motor its pretty straight forward, but main concerns are when dealing with LV distribution where unbalanced load exist.
For LV distribution, normally the power supply from LV Switchgear to LV MCC utilizes big cables (150sqmm - 300sqmm). The same case also applies to LV Switchgear Busbar Rating. To save copper, some people opt for lower neutral busbar rating compared to the phase busbar.
As I understand, recently either IEC or NEC requires the neutral busbar to be of the same size as the phase busbar. Can anybody point out to which clause in IEC or NEC that mentioned this.
Appreciated it. Thanks.
