What is the speed of the bat gaining on its prey in m/s?
The discussion focuses on calculating the speed at which a bat is gaining on its prey, specifically a flying insect. Given the bat's speed of 6.3 m/s and the frequency of the emitted and received chirps, the Doppler effect equations are applied to find the insect's speed. The calculations reveal that the insect is moving at approximately 5.34 m/s. By subtracting the insect's speed from the bat's speed, the bat is gaining on its prey at a rate of about 1.96 m/s. This analysis demonstrates the application of the Doppler effect in determining relative motion between the bat and its prey.
bastige
Assume: Take the speed of sound in air to be 341 m/s.
A bat, moving at 6.3 m/s, is chasing a flying insect.
The bat emits a 47 kHz chirp and receives back an echo at 47.73kHz.
At what speed is the bat gaining on its prey? Answer in units of m/s.
f=initial frequency
fo=observed frequency
x= velocity of insect
f(observed)=f(init){(v+v[observer])/(v-v[source])}
I determined the bat is the source, but because the chirp bounds off the insect and returns to the bat, I considered the insect to be the "source" in my equation:
Using the above equation:
f/fo=(343+Vbat)/(343+x)
46000/47730=(341+6.3)/(341+x)
.9637=347.3/(341+x)
341+x=346.3363
x=5.3363
then i take the velocity of the bat:
5.9-3.939=1.96
At first the frequency received by the prey is:
\nu' = \nu (\frac{v-v_{L}}{v-v_{S}})
Now, as you said correctly, the wave is reflected back and the the source and listener interchange to give us this i.e. the bat becomes the listener and the prey the source of the reflected sound wave:
\nu'' = \nu (\frac{v+v_{S}}{v+v_{L}})
putting the two equation together we get:
\nu'' = \nu (\frac{v-v_{L}}{v-v_{S}}). (\frac{v+v_{S}}{v+v_{L}})
Substituting the values, find the velocity of the prey and then find the relative velocity of the prey w.r.t the bat.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
