What is the speed of the block as it leaves the table?
  • Thread starter Thread starter urbettybo0p
    Block Speed Table
The discussion revolves around a physics problem involving a bullet colliding with a block on a frictionless table. Key questions include determining the speed of the block after impact, the change in kinetic energy of the system, and the distance the block travels after falling. Participants emphasize the importance of showing prior work to receive assistance and highlight that the original poster's multiple posts were inappropriate for the forum. The conversation suggests that help has already been provided in more suitable homework forums, indicating a need for proper forum etiquette and adherence to guidelines.
urbettybo0p
Hi, I really need help on the following questions and would appreciate it if someone could ASAP! Thank you!
1) a bullet of mass m is moving horizontally with speed v when it hits a block of mass 100m that is at rest on a horizontal frictionless table. The surface of the table is a height h above the floor. After the impact the bullet and the block slide off the table and hit the floor a distance x from the edge of the table.
a) What is the speed of the block as it leaves the table?
b) What is the change in kinetic energy of the bullet-block system during impact?
c) What is the distance x ?
Suppose the bullet passes through the block instead of remaining in it.
d) State whether the time required for the block to reach the floor from the edge of the table would now be greater, less, or the same. Justify your answer.
e)State whether the distance x for the block would now be greater, less or the same. Justify your answer.
THANK YOU SOOOOOO MUCH! I really needed help.
1) Wrong forum.
2) show us what you have done first, and we'll try to help you from there.
franznietzsche said:
1) Wrong forum.
He/she quadruple posted this at the same time then got testy when I called him/her on it. Help has already been provided in the homework fora.
TL;DR Summary: I want to do a PhD in applied math but I hate group theory, is this a big problem? Hello, I am a second-year math and physics double major with a minor in data science. I just finished group theory (today actually), and it was my least favorite class in all of university so far. It doesn't interest me, and I am also very bad at it compared to other math courses I have done. The other courses I have done are calculus I-III, ODEs, Linear Algebra, and Prob/Stats. Is it a...
Yesterday, 9/5/2025, when I was surfing, I found an article The Schwarzschild solution contains three problems, which can be easily solved - Journal of King Saud University - Science ABUNDANCE ESTIMATION IN AN ARID ENVIRONMENT https://jksus.org/the-schwarzschild-solution-contains-three-problems-which-can-be-easily-solved/ that has the derivation of a line element as a corrected version of the Schwarzschild solution to Einstein’s field equation. This article's date received is 2022-11-15...
