What is the State Postulate and How Does it Relate to Thermodynamic Properties?
  • Context: Graduate
  • Thread starter Thread starter aiklone1314
    State
The State Postulate in thermodynamics asserts that the state of a simple compressible system can be determined by two independent, intensive properties. According to "Thermodynamics: An Engineering Approach, 6th Edition," temperature and pressure are interdependent in multiphase systems but independent in single-phase systems. For instance, at a constant pressure of 1 atm, water boils at 100 degrees Celsius, indicating that pressure remains constant while temperature increases. The discussion confirms that knowing two independent properties, such as temperature and specific volume, allows for the determination of the system's phase, regardless of whether the properties are dependent or independent.
  • Understanding of thermodynamic properties
  • Familiarity with the concepts of phase transitions
  • Knowledge of intensive and extensive properties
  • Basic principles of compressible fluid mechanics
  • Study the implications of the State Postulate in complex systems
  • Learn about phase diagrams and their applications in thermodynamics
  • Explore the relationship between temperature and pressure in multiphase systems
  • Investigate the role of specific volume in determining the state of a compressible system
Students and professionals in mechanical engineering, chemical engineering, and thermodynamics who seek to deepen their understanding of state properties and phase transitions in compressible systems.
aiklone1314
I was refer to the textbook thermodynamics an engineering approach 6th edition, at page 14&15, the definition is that a state is specified by two independent, intensive properties for a simple compressive system.
The book says that temp. & pressure is dependent on each other at multiphase and independent to each other on single phase.
I was wondering if the pressure is held constant , let's say 1atm, and the water is boils until it reaches 100 degree celsius the water starts to change phase to gas. That means the pressure is independent of the temp. right?because when the temp. increasing, the pressure remains constant. But why the book says it is dependent on multiphase?
Science news on Phys.org
Is state postulate means we can know the state of a compressible system if we know two properties of it?State in the book means phase right?
I found that whatever if we use two completely independent properties or two dependent properties at multiphase we can also know it's phase.
E.g: two completely independent properties: Temp. & Specific Volume.
If we know the temp. & specific volume of the compressive system, then we can know it's phase/state.
two dependent properties at multiphase : Temp. & Pressure.
If we know the Temp. & Pressure. of the compressive system, we can also know it's phase/state.
Given: Temp:100degree celsius, P:1atm
we know it is gas.
Or at a specific height mountain : 95degree celsius, P:0.95atm
we know it is also a gas.
