What is the tension in a rope for a moving box in Newton's Second Law?
  • Thread starter Thread starter ideefixem
    Tension
The discussion focuses on calculating the tension in a rope supporting a 50kg box under different conditions using Newton's Second Law. For a steady upward velocity of 5.0 m/s, the tension is determined to be 490N, while for an upward acceleration of 5.0 m/s², the tension increases to 740N. Participants emphasize the importance of understanding the forces acting on the box, specifically weight and tension, and suggest using a Free Body Diagram for clarity. The derivation of the tension formula T = m(g + a) is confirmed as correct. Overall, the thread highlights the application of Newton's laws in solving real-world physics problems.
ideefixem
Greetings everyone.
This is my first post and I'm currently enrolled in a general physics I class. We are studying Newtons Second at the moment.
A 50kg box hangs from a rope. What is the tension in the rope if:
a- The box moves up a steady 5.0 m/s
b- The box has vy= 5.0 m/s and is speeding up at 5.0 m/s^2
a->= F->net/m
(Fnet)x=max
(Fnet)y=may
I was out last Friday when this topic was discussed. The above question is one of the few review/summary questions available for extra practice. I don't want to fall behind so I'm just want to catch up for class tomorrow.
Any hints or ideas as to where to start would be much appreciated!
Thanks
Alright,
Could you tell me if I am heading in the right direction here?
B)
m=50kg
v=5.0m/s
a=0m/s^2
f=ma=m(g+x)
f=50kg(9.8m/s^2+0)
tension=490N
C)
f=ma=m(g+x)
f=50kg(9.8+5.0)
tension=740N
those answers are right.
Hm...just curious did you derive f=m(g+x) from F=ma? or was that given to you?
It wasn't given to me. I assumed it... is it still correct?
yes, but you should know how to derive it:
since the block is hanging from a rope you know all the forces acting on it, weight and tension of the string.
If you can't see it you can draw a Free Body Diagram, so Tension is pointing upward. weight is pointing down.
using Newton's second law for the y component and using the up direction as positive you will get:
T-mg=ma
T=m(g+a)
because there's only those 2 forces acting on the block, if there were more like multiple strings you'd just use Newton's 2nd law and add up all the forces keeing in mind the +/- direction that you choose.
Thank you for your help.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
