What is the tension in each cord?
  • Thread starter Thread starter kaytee28
    Tension
The discussion revolves around calculating the tension in cords supporting two 3.5 kg paint buckets. For part (a), when the buckets are at rest, the tension in the upper cord is equal to the weight of both buckets, while the lower cord's tension equals the weight of the lower bucket alone. In part (b), when the buckets are accelerated upwards at 1.80 m/s², the tension in the upper cord increases due to the additional force required for acceleration, while the lower cord's tension also reflects this acceleration. Participants emphasize the importance of drawing free body diagrams to visualize forces acting on each bucket. Understanding these concepts is crucial for solving the tension problems accurately.
kaytee28
One 3.5 kg paint bucket is hanging by a massless cord from another 3.5 kg paint bucket, also hanging by a massless cord.
(a) If the buckets are at rest, what is the tension in each cord?
(lower cord)
(upper cord)
(b) If the two buckets are pulled upward with an acceleration of 1.80 m/s2 by the upper cord, calculate the tension in each cord.
(lower cord)
(upper cord)
I'm not sure on what equations to use or anything.
Everything I've been doing is wrong. I tried adding it up and dividing by gravity, then subtracting and dividing by gravity and I don't know what else to do.
Em you might want to solve your original problem first, that should help you with this one, and it's not really advisable to try to do 2 together.
I'm not doing it together. I put it up now so I wouldn't forget about it?
Step 1: Draw the free body diagram, and label all the forces acting on both buckets.
Have you done this? Describe all the forces you've got.
Example: Forces acting on upper bucket are <blah1> in the <foo1> direction, <blah2> in the <foo2> direction, etc.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
