What is the total force exerted by block 2 on block 3 ?
  • Thread starter Thread starter aruji73
    Block Force
The discussion centers on calculating the total force exerted by block 2 on block 3 in a system of four blocks on a frictionless table. Initially, a participant calculated the force as 67.5 N, which was incorrect. They later considered the combined weight of the two blocks above block 2, calculating it as 196 N, but still faced issues with the horizontal force component. The conversation emphasizes the importance of analyzing both horizontal and vertical forces to determine the net force accurately. Ultimately, the correct approach involves understanding the vector nature of the forces acting on the blocks.
aruji73
Four blocks EACH of mass m = 10.0 kg are arranged as shown in the picture, on top of a frictionless table. A hand touching block 1 applies a force of Fh1 = 90.0 N to the right. The coefficient of friction between the blocks is sufficient to keep the blocks from moving with respect to each other.
I got 67.5 N which was wrong
F=90N-22.5=67.5N since a=9/4ms-2
Start by drawing a free-body diagram showing all the forces. Pay particular attention to blocks 2 and 3, but don't ignore the others.
I now think block 2 would exert a force to block 3 equal to the combined weight of the 2 books above it which is f=2(mg) = 2*10*9.8 = 196 N
but i still get it wrong
That's part of it, but what about the horizontal direction?
i got it now its sqrt(of horizontal direction ^2 + vertical direction ^2)
Assuming you are referring to the forces on the block, that is indeed the magnitude of the net force. Now what is the direction?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
