What is the Velocity of a Ball Thrown Vertically Upward at a Height of 96 Feet?
  • Thread starter Thread starter morphine
The discussion revolves around determining the velocity of a ball thrown vertically upward when it reaches a height of 96 feet. The problem involves the use of a quadratic equation to model the ball's height over time and requires differentiation to find the velocity.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the differentiation of the height equation and the implications of the terms involved. There are questions about the derivation of certain terms and the correct application of limits in calculus. Some participants suggest solving for the time when the ball reaches 96 feet before calculating the velocity.
The discussion is active with participants exploring various interpretations of the problem. Some have provided guidance on solving for time and substituting it back into the velocity equation. There is recognition of multiple times at which the ball reaches 96 feet, leading to different velocity values.
Participants note that the problem is part of a multiple-choice question, which may influence their approach to finding the correct answer. There is also mention of potential confusion regarding the quadratic equation derived from the height function.
morphine
If a ball is thrown vertically upward with a velocity of 80 ft/sec,
then its height after t seconds is given by
s = 80t - 16t2
. What is the velocity of the ball
when it is 96 feet above the ground on its way up?
I have found my way to s'(t) = -16h -32t + 80
which I believe to be right. But now I'm not sure what to do. Do I need to find the second derivative?
Where does 16h come from in your equation for s dot? You just need to solve for the time when the ball is at 96 feet.
Where did you get the -16h term in s'(t)?
My intermediate step is: (-16t^2 - 32th - 16h^2 + 80t + 80h + 16t^2 - 80t) / h
Then I cancel out like terms, factor out the h and cancel it. Then I'm left with s'(t) = -16h -32t + 80.
Where have I gone wrong?
You forgot that the derivative is the limit as h approaches 0.
You left out the most important part of your limit definition!
Argh, it's these little things that kill me in math!
So the h term becomes 0, so:
s'(t) = 80 - 32t
But I'm still unclear how I get the velocity at 96 feet. I recognize that the velocity is the slope of the tangent line but... Oh wait 32 would be the slope of that line, correct? So the answer is -32??
First you have to solve the position equation for t, then find the velocity at that t.
Use the formula for s(t) to find the time t when s(t) is equal to 96. Then substitute that time into your formula for s'(t) - the velocity.
For example (and these aren't the right numbers) suppose you found that s(t) = 96 for t = 12 sec. Then you would evaluate s'(12) to get the instantaneous velocity at t = 12 sec.
Not getting anywhere with that, sorry I need another hint.
All I've been able to come out with are answers that don't make sense.
By the way, it's multiple choice, and the possible answers are: 80, -80, 32, 16, -16 feet/sec
Show us what you're trying to do and we'll set you straight.
OK.
96 = 80t - 16t^2
96 / 16 = (80t -16t^2) / 16
6 = 5t - t^2
y = -t^2 + 5t +6
y = -1(t + 2)(t + 3)
soooo t = -2 or -3?
I feel like I am going about this the wrong way... Plugging either of those in gets a number above 100.
morphine said:
OK.
96 = 80t - 16t^2
6 = 5t - t^2
So far, so good, but you're making this harder than it should be. I would have written 16t^2 - 80t + 96 = 0 as my 2nd equation here. Then I would divide by 16 on both sides to get
t^2 - 5t + 6 = 0.
This factors to (t -3)(t - 2) = 0, so t = 2 or t = 3.
morphine said:
y = -t^2 + 5t +6
Where did y come from?
soooo t = -2 or -3?
From my work above, the times when the ball is at 96 ft are t = 2 and t = 3. Use your formula for velocity (s'(t)) to find the velocity at these two times. You should find that the two velocity values are numerically equal but opposite in sign.
Right you are, so I get 16 on the way up or -16 on the way down. Thanks for your help!
Be sure to include units - ft/sec.
  • · Replies 19 ·
9K
  • · Replies 36 ·
  • · Replies 17 ·
