What is the velocity of mass2 after dropping 3cm in a tension/friction problem?
  • Thread starter Thread starter hadoken22
The discussion revolves around a physics problem involving two masses connected by a string over a frictionless pulley. The user initially calculated the acceleration of mass2 after it dropped 3 cm but arrived at an incorrect velocity of 11.24 cm/s, while the textbook claimed it should be 83 m/s. Upon review, it was suggested that the user may have mixed up units, particularly between centimeters and meters. After converting to SI units, the user recalculated and found the acceleration to be 1.163 m/s², resulting in a corrected velocity of 0.835 m/s. The importance of unit consistency in physics calculations is emphasized in resolving the discrepancy.
hadoken22
Hello. I've been doing this problem and cannot seem to get the correct answer. I'd really appreciate some help. In the problem, mass1(250g) rests on an inclined plane that is 30 degrees above the horizontal, and whose coefficient for kenetic friction is .1. M1 is attached to a frictionless pulley at the top of the plane, with a string. Hanging off of the pulley is mass2(250g), attached to the string. When mass2 has dropped 3cm, what is its velocity?
This is what I have done so far. I summed up the forces on m1 and m2 separately:
#1 sumFym1=Fnormal-m1gcos30=0 (NOTE:I am using the inclined plane as my reference/x-axis, rather than the ground.)
#2 sumFxm1=T-Ffriction-m1gsin30=m1a
#3 sumFym2=T-m2g=-m2a
Fn=m1gcos30
Ffriction=.1Fn=.1m1gcos30
I substituted this value for Ffriction and then tried solving the system of equations by subtracting #3 from #2. The tension canceled out and I solved for acceleration. I got a=2.107cm/s^2. Using v^2=V0^2+2as, the velocity turned out to be 11.24cm/sec . My textbook says the answer is supposed to be 83m/s. I am doing something wrong, but cannot figure out what. Any help would be appreciated.
Thanks!
Your equations look correct, but your answer for "a" seems way off. Did you mix up units? (cm vs. m, for example) (The book's answer seems off as well.)
Hi. You were absolutely right! After converting to SI units, I repeated the problem and got acceleration to be 1.163m/s^2. The velocity turned out to be .835m/s^2. Thanks for the help. I really appreciate it!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
