What is the work done by kinetic friction on a block sliding down a ramp?
The discussion revolves around calculating the work done by kinetic friction on a block sliding down a ramp. The block has a mass of 25.0 kg, the ramp is 5.00 m long and elevated at an angle of 36.0 degrees, with a kinetic friction coefficient of 0.220.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the definition of work in the context of friction, questioning whether the work done by friction can be zero or negative based on the direction of the force relative to displacement.
There is an active exchange of ideas regarding the nature of work done by friction, with some participants asserting that work is negative due to the opposing direction of friction, while others challenge the initial assumption that work could be zero.
Participants reference the need to consider the net force acting on the block and the angle between the force of friction and the direction of motion, indicating a deeper exploration of the physics concepts involved.
pdrjuarez
A 25.0 kg block slides down a 5.00 m ramp that is elevated at 36.0 degrees. The kinetic friction coeff. is 0.220.
-What is the work done by friction as the block slides down the ramp?
Ok, so as far as I know, work is achieved only if you apply a force on something and move that something in the same direction as the force. Here, friction is applying a force of 43N (I calculated it), but it's not achieving motion in the same direction. Therefore, work done by friction is 0.
Am I right?
Work done is not 0, its simply negative.
You are right that W = Fd. But friction does apply a force, and the object does move, just in the opposite direction. So the work is F*(-d)
Am I right?
Nope. :) Positive work is produced when the force and displacement are parallel.
Take a look at the vector expression for work:
[tex]W=\vec F\cdot \vec d[/tex]
[tex]W=Fd\cos{\theta}[/tex] where [tex]\theta[/tex] is the angle between the force and displacement vectors.
This way, I hope you can see that work can be either positive, negative, or zero. All depending on [tex]\cos{\theta}[/tex]
Review your notes
Straight out of a physics textbook, Work done on a particle by a constant force (constant magnitude and direction) is defined to be the product of the magnitude of its displacement (d) times the component of the force parallel to its displacement.
In equation form, [tex]W=F_{net}d \cdot cos\theta[/tex]
Remember that it says Fnet, not F. Remember also, there is only a net force on the object if [tex]a\neq0[/tex] So you can only do work if there is a net force on the object. The exception is if the question is asking you to determine the work done by a specific force, other than the net force.
In your question the force of friction IS your net force. So assuming your calculation for the force of friction is correct (i won't check it) Fnet = 43N. Remember, Friction opposes the direction of motion ALWAYS. What way is your object moving? In which direction does the force of friction act?
remember that when theta is 180 degrees (opposite to the direction of motion) cos 180 degrees equals -1. Which would imply the work done by friction is always NEGATIVE...
Try again and let me know :)
  • · Replies 32 ·
  • · Replies 16 ·
  • · Replies 58 ·
