What Materials and Calculations Are Best for Building a Micro Motor?
To construct a micro motor, selecting materials for internal electromagnets is crucial, with iron, steel, and certain alloys recommended for their high magnetic permeability. Calculating the amperage input and output force involves using Ampere's Law and equations for force and torque in a magnetic field. The suggested equations include B = μ0 * N * I for magnetic field strength and F = B * I * l for force on a conductor. Additionally, incorporating permanent magnets can enhance the motor's strength and efficiency. This guidance aims to assist in successfully building a functional micro motor.
ugsquish
Ok, I want to start by saying I have been out of this field for some time and I have regrettably lost a lot of my knowledge. So I may require a little patients, but here it goes.
I am wanting to construct a micro motor. I was trying to decide on what materials to make the internal electromagnets from for max capability.
I want the motor to be no more then 1/2" in height & 1.5-2" diameter. what materials should i use and what calculations should i use to calculate amperage input to lb output of the motor.
i realize it may be asking a lot but I hope you all can help :)
there are plenty of examples of small motors like that
any hobby shop sells them ... buy one ... pull it apart and find out how they do it and see if you have the capability to reproduce that.
I suggest it will be very difficult for some one to do at home
Dave
Thank you for your reply. I will look into your sugjestion.
Time was when people used to home-build a lot of electrical items. These days, small items are so well designed and perform so well (often for pennies) that it's just not worth trying to do what hi tech assembly can do easily. Tiny motors are fantastic these days. Don't try to compete - but there's everything to be said for trying to make a motor that 'actually works' from simple materials. Then buy one for your application!
Hello, thank you for reaching out. It's great that you are interested in constructing a micro motor and I am happy to assist you with your questions.
To determine the best materials for your internal electromagnets, you will need to consider several factors such as the strength of the magnetic field, the size and shape of the magnets, and the power consumption. Some common materials used for electromagnets include iron, steel, and certain types of alloys. These materials have high magnetic permeability, which means they can be easily magnetized and demagnetized.
To calculate the amperage input and lb output of the motor, you will need to use the following equations:
1. Ampere's Law: This law states that the magnetic field created by an electric current is directly proportional to the current and the number of turns in the coil. The equation is B = μ0 * N * I, where B is the magnetic field, μ0 is the permeability of free space, N is the number of turns in the coil, and I is the current.
2. Force on a current-carrying conductor in a magnetic field: This equation helps determine the force exerted on a conductor placed in a magnetic field. The equation is F = B * I * l, where F is the force, B is the magnetic field, I is the current, and l is the length of the conductor.
3. Torque on a current loop in a magnetic field: This equation is used to calculate the torque on a current-carrying loop placed in a magnetic field. The equation is τ = B * I * A * sinθ, where τ is the torque, B is the magnetic field, I is the current, A is the area of the loop, and θ is the angle between the magnetic field and the normal to the loop.
Using these equations, you can calculate the required current and magnetic field strength for your micro motor. Additionally, you can also consider using permanent magnets in combination with the electromagnets to increase the overall strength and efficiency of the motor.
I hope this information helps you in your project. If you have any further questions, please don't hesitate to ask. Best of luck with your micro motor construction!
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
