What Motor Can Handle 200kg on a 15-Degree Incline?
The discussion centers on designing an electric wheelchair capable of handling a 200kg load on a 15-degree incline, requiring each of the two motors to provide 28.5Nm of torque. The user is considering a brushless permanent magnet DC motor but is open to alternatives. Suggestions include using a series-wound DC motor, which, while larger, can deliver high starting torque and can be adjusted for performance. A potential motor specification mentioned includes 19.6Nm of torque at 7500rpm, which could be geared down to meet the required torque. Overall, the focus is on finding a lightweight motor that meets specific torque and speed requirements for the wheelchair design.
melanie_new
Heya,
Well...I am making/designing an electric wheelchair which should be able to move a maximum load capacity of 200kg. The worst case scenario is the chair is fully loaded and going up an ambulance ramp of incline 15degrees.
I've decided to have two small motors for two wheels.
I find the maximum torque requirements from my specs to be 28.5Nm required from each motor! I know I can apply a gearing ratio to cut this down. My maximum wheel velocity has to be 1600RPM. Can anyone suggest how I can find a electric motor that meets these specs that's also light! I was thinking of a brushless permanent magnet DC motor.
Any help would be much appreciated.
x
Hi melanie_new,
Well we used some motors from scrap in one of our projects. 200kg is pretty heavy load and in your case i think you'll need high starting torque and max. speed . So this calls for a series-wound DC motor. Though it's size is very big they can be properly adjusted and clamped to get the desired results. one motor of this type can weigh upto 7kg max. Approx. specifications are:
torque at 7500rpm is 19.6 Nm and if reduced by half you would get the desired torque of 38 Nm approx. at a speed of 3000 rpm,is that ok?
Hey thanks for the advice
Nope, lynch motors are good.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
