What Should the Mass of W Be to Support a 77 kg Person's Head?
To support the head of a 77 kg person using a pulley system, the mass of W must counteract the weight of the head, which is approximately 5.39 kg (7% of body weight). A free-body diagram is essential to analyze the forces involved, particularly the tension (T) in the rope. The tension acts upward on the head while also being distributed through the pulleys, with two forces acting vertically and two at a 37-degree angle. The total vertical force on the head is the sum of the vertical components of these tensions. Understanding these forces is crucial for determining the appropriate mass of W to ensure proper support during neck healing.
dREAPER
When a patient’s injured neck is healing, it is often desirable to prevent the weight of the head from pushing down on the neck. This can be accomplished with the system of pulleys shown in the figure. The pulleys are all small and extremely light in weight and have no appreciable friction. Typically, a person’s head makes up 7.00% of his or her body weight.
If the head of a 77.0 kg person is to be supported completely by the apparatus shown, what should the mass of W be? Start with a free-body diagram of the head.
I drew out a free body diagram, but don't know where to go from there.
Where is the figure?
If the tension in the rope is T, what is the force exerted by the apparatus on the head?
mg? With T pointing upward.
T points along the rope. There are four places where the tension exerts forces on the wheels. At two of these places, T points upward, and at the other two it points at an angle of 37 degrees to the vertical. You have to find the vertical componets of all these and add them up to find the total vertical force exerted on the head.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
