What Torque is Needed to Accelerate a Flywheel to 400 rev/min in 8 Seconds?
The discussion focuses on calculating the constant torque required to accelerate a flywheel with a moment of inertia of 2.50 kg m² to an angular speed of 400 revolutions per minute (rev/min) in 8 seconds. The correct torque, calculated using the equations W = Wo + αt and T = αI, is determined to be 13.0895 N*m. The confusion arises from a comparison with an incorrect method found online, which improperly multiplies time by 60 seconds, leading to an erroneous calculation. The participant confirms their solution is accurate and seeks clarification on the incorrect approach.
  • Understanding of angular motion and torque concepts
  • Familiarity with moment of inertia calculations
  • Knowledge of unit conversions between revolutions per minute and radians per second
  • Proficiency in applying kinematic equations for rotational motion
  • Study the relationship between torque and angular acceleration in rotational dynamics
  • Learn about the implications of moment of inertia in different physical systems
  • Explore unit conversion techniques for angular velocity
  • Investigate common pitfalls in solving rotational motion problems
Students in physics or engineering courses, educators teaching rotational dynamics, and anyone interested in understanding torque calculations in mechanical systems.
kk727
The flywheel of an engine has a moment of inertia 2.50 (kg)m^2 about its rotation axis.
What constant torque is required to bring it up to an angular speed of 400 rev/min in a time of 8.00s, starting from rest?Time (t) =8.00 sec
Ang Velocity (W) = 400 rev/min
Moment of Inertia (I) = 2.50 kg m^2
W=Wo+αt
T = αI
So, I converted the 400 rev/min to rad/sec.
400 * 2pi/60sec = 41.8876 rad/sec
I then plugged everything into the first equation to solve for angular acceleration.
41.8876 rad/sec = 0 + α(8 sec)
α = 5.2358 rad/sec^2
I then found torque using T=αI.
T=(5.2358)(2.50)
T=13.0895 N*m
Now, I thought that was the answer, so I tried looking up the question online to verify it. I found this:
http://answers.yahoo.com/question/index?qid=20101018171042AAmoOu0
I followed the same step process, but my only question is this -
From Yahoo Answers website...w (final) = w (initial) + (c) x time (t)
15pi= 0 + c(8.10x60seconds)
c= 0.0969
Why did that person multiply the time by 60 seconds? I did everything the same as them, except for this. Can someone explain why?
For no apparent reason. Your solution is correct; his isn't.
Hahaha, okay, it totally confused me and made me doubt everything that I did...thanks for the verification! :)
  • · Replies 18 ·
28K
