What volume would this air occupy at STP?
  • Thread starter Thread starter Bigworldjust
    Air Volume
The discussion revolves around calculating the volume of air from a compressed tank at standard temperature and pressure (STP). The user initially calculated the volume using the ideal gas law but arrived at an incorrect value of 0.0056 m³. After further consideration and checking Avogadro's law, the user corrected the conversion, determining the correct volume to be 0.56 m³. The conversation highlights the importance of accurate unit conversion in gas law calculations. Overall, the correct volume of air at STP from the tank is 0.56 m³.
Bigworldjust
A 12.0 cm-diameter compressed-air tank is 50.0 cm tall. The pressure at 30.0 C is 110 atm .
V=nRT/P
The first question asked to find the amount of moles of air in the tank, and got it right with an answer of 25. So I plugged in:
(25mols)(.0821)(273K)/(1*10^5)
And got .0056 m^3, but that seems to be wrong. Any help would be appreciated. Thanks!
Check into Avogadro's law. An ideal gas occupies a specific number of litres per mole at STP.
Ah okay, so I converted wrong. It would be .56 m^3. Thanks!
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
