What would a good design for a High RPM Altenator be?
  • Thread starter Thread starter Qaiphyx
    Design Rpm
A good design for a high RPM alternator should consider the specific power requirements based on expected loads and additional parasitic losses such as friction and rotor windage. Calculating the horsepower needed involves understanding the alternator's weight and the RPM range, which is suggested to be between 10,000 to 15,000 RPM. Using a standard three-wave alternator may be feasible for high RPM applications, but design specifics should be tailored to the intended performance. It's crucial to ask detailed questions regarding design parameters to optimize efficiency and output. Overall, careful consideration of these factors will lead to a more effective high RPM alternator design.
Qaiphyx
And how would I do all the math for how much HP I would need to turn it based on its weight etc.?
Would I just use a normal 3 wave alt for high RPMs? Like roughly... 10-15000rpms
How about asking more specific questions in regard to designs?
The power required will be a function of the loads applied. How much power are you expecting from it? The power input will have to be at least that plus parasitic loads like friction and rotor windage.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
