Where Did I Go Wrong? Troubleshooting a Commutator Relation
  • Thread starter Thread starter Spinny
    Commutator
The discussion revolves around troubleshooting a commutator relation involving the Dirac Hamiltonian and angular momentum components. The user is attempting to derive the relation [H_D, L_k] = -iε_{kln}α_l p_n but is missing the factor of -i in their final result. Feedback suggests that the user unnecessarily included the term βm, as it commutes with everything, and that the angular momentum operator is incorrectly defined, which may lead to discrepancies in signs. The confusion arises from mixing notations for angular momentum, where the conventions used in calculations differ from those in the provided solution. Overall, the user is encouraged to review their definitions and notations to resolve the issue.
Spinny
Hi, I've got a commutator relation I'm trying to figure out here. I don't know what I'm doing wrong, but I don't seem to be able to get it right, so hopefully someone can help me through it.
Anyway, here's the problem. We're given the Dirac Hamiltonian H_D = \alpha_j p_j + \beta m, where p_j = -i\nabla_j and the angular momentum components L_k = i\epsilon_{kln}x_lp_n. We are then going to show the commutator relation
[H_D,L_k] = -i\epsilon_{kln}\alpha_lp_n
Here's what I've got so far:
[H_D,L,k]\psi = (H_DL_k-L_kH_D)\psi
=(\alpha_j p_j+\beta m)i\epsilon_{kln}x_lp_n\psi -i\epsilon_{kln}x_lp_n(\alpha_jp_j+\beta m)\psi
=\alpha_j p_j i\epsilon_{kln}x_lp_n\psi +\beta mi\epsilon_{kln}x_lp_n\psi -i\epsilon_{kln}x_lp_n\alpha_jp_j\psi-i\epsilon_{kln}x_lp_n\beta m\psi
So far, (hopefully) so good. Now, as far as I can see, the second and the last part cancel, so we're left with
[H_D,L_k]\psi = \alpha_j p_j i\epsilon_{kln}x_lp_n\psi - i\epsilon_{kln}x_lp_n\alpha_jp_j\psi
Rewriting the first part we get
i\epsilon_{kln}p_n\alpha_j p_j(x_l\psi)
and knowing that p_j is a differential operator, we use the product rule, and get
i\epsilon_{kln}p_n(\psi \alpha_j p_j x_l + x_l\alpha_jp_j \psi)
We then have that p_j x_l = -i for j = l, and 0 for j != l. Thus
i\epsilon_{kln}p_n(-i\alpha_l\psi + x_l\alpha_jp_j\psi)= \epsilon_{kln}p_n\alpha_l \psi+i\epsilon_{kln}p_nx_l\alpha_jp_j\psi
Putting this back in we get
[H_D,L_k]\psi = \epsilon_{kln}p_n\alpha_l \psi+i\epsilon_{kln}p_nx_l\alpha_jp_j\psi- i\epsilon_{kln}x_lp_n\alpha_jp_j\psi
But now the last two parts cancel, and we're left with
This is almost what I was supposed to get, only the factor -i is missing. It seems so close, so hopefully I'm not way off, but, where did I go wrong?!?
One observation (not a solutoin to your problem, but i'll grt some paper for that in a second), is that you unnecessarily include the beta m in you calcs.
if H=a_jp_j+bm, then commutating anything with H is the same as commutating it with just a_jp_j since bm is a constant and commutes with everything (it is a central element).
you also don't need to include the phi either.
just in case you want to write this out in latex again you can save yourself some bother.
I think you have you angular momentum operator slightly wrong (i'm not an expert here) but it ought to be
L_k =-i\epsilon_{lkn}x_k\partial_n
this changes everything in your post by a factor if -i as required I think, though I've not gotten down to checking the signs with any great enthusiasm. (i'm a pure mathematician, and so if it's true up to minus signs [we call this mod 2] then it's true full stop.)
Thanks for your insight. I'm not able to see, however, how it is the ang. mom. that's incorrect. The -i still comes from the mom. in the hamiltonian and cancel the i in the ang. mom.
Anyway, I'm still having trouble finding out where that ang. mom. actually came from, I haven't been able to find a similar anywhere yet (at least not one I recognize as the one given in this problem). If I ever get in the mood again, I'll review the problem with your insight in mind.
The angular momentm components are incorrectly written. They should either be written without the "i" (when writing in terms of momentum components) or as Matt says (on plugging in for the mom. components).
Also note that the non-rel KE term is written using Einstein notation, so it really is the sum of all three products (ie : \sum_{j=k,l,n} \alpha _j p_j ).
The problem is that you're mixing notations. Angular momentum can be with or without the i, but that changes it from a nabla to a p or back again. So, you're using one convention in your working out but the solution is written with the other convention, that is why they don't agree. At least, that is my analysis: i checked this relation and that seems to be the problem.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
