Where Did the Energy Come From? A Physics Puzzle on Entropy and Magnetism
  • Thread starter Thread starter luthier
    Fun Physics
The discussion centers on the phenomenon of magnets spontaneously organizing into a structured block when placed in a bag, raising the question of where the energy comes from to decrease entropy. It highlights the principle that reducing entropy typically requires energy input. One participant explains that the magnetic field itself stores energy, and when magnets come together, the net magnetic field's energy decreases. This energy change occurs due to the work done on or by the magnets as they are moved closer together. The conversation concludes with a light-hearted acknowledgment of the complexity of the topic.
luthier
First off, I may or may not know the correct answer to this one...
Here it is..
I have a set of say 100 small perminent magnets which are randomly oriented
in space. I also have an empty burlap sack. I grab each of the magnets one at
a time and throw each one into the bag until all 100 are in the bag.
I then look inside the bag to find that all 100 magnets have attached themselves
to one another to form a single well ordered block of 100.
Remember that there is a law which states that in order to lower entropy you
must add energy in order to "pay" for the decrease in entropy.
The magnets went from a maximum entropy state to one of nearly the most ordered
orientation. Where did the energy come from to lower the entropy ?
Tim
The magnetic field stores energy. When two bar magnets come together (or any set of magnetic dipoles) the resulting net magnetic field is weaker in the amount of energy stored than the fields produced when the two magnets are apart. The energy injected or extracted from the fields is the work done on or by the magnets when they are physically moved in the vicinity of each other.
Ok, I guess I will have to come up with a better one ! :-)
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
