Where Does Frictionless Energy Go?
  • Thread starter Thread starter aviator
    Energy
The discussion centers on the dynamics of a spinning mass transitioning from a radius of 100 m to 1 m while maintaining a speed of 100 m/s in a frictionless environment. It highlights the conservation of angular momentum, indicating that as the radius decreases, the speed must increase to conserve total angular momentum. The conversation also clarifies that if the radius is reduced without external torque, the linear speed cannot remain constant at 100 m/s; instead, it must increase significantly. Participants emphasize the importance of specifying the scenario, as the mechanics differ based on whether the mass is actively pulled in or allowed to wrap around a pole. Ultimately, the conversation underscores the complexities of rotational dynamics and the necessity for precise definitions in physics discussions.
aviator
i have a device where a spinning mass switches from a radius of 100 m to a radius of 1m by means of gearing, going the mass of 1 kg at a speed of 100 m/s
lets consider it frictionless
in order to reduce the radius i have to aply a work, the energy to aply that work comes from the 100 m/s of the mass because there's no other energy in the system
so when the ball has a radius of 1 m it has a lower speed having lost kinetic energy
my question is if the device is frictionles where has this kinetic energy gone to?
I`m not sure what you mean exactly, but when you reduce the radius of the spinning object it will start to spin faster (conservation of angular momentum), so it picks up rotational kinetic energy (equal to the work you performed to bring the mass closer to the axis of rotation).
a ball is geared to an axe in such way that the radius decreases constantly as it spins
would it be correct to say that because of conservation of momentum if when it has a radius of 100 m has a speed of 100m/s when it has a radius of 1 m still has a speed of 100 m/s?
No, since the initial angular momentum is rmv=(100)(1)(100) = 10.000 kg m^2/s, when the ball
spins with a radius of 1m, the angular momentum will be still be 10.000 kgm^2/s =(1)(1)(v). So v=10.000 m/s.
If you pull in the ball radially, the torque on the ball will be zero, so its angular momentum is conserved.
Linear momentum obviously is not, since the ball rotates (there's a centripetal force acting on it).
you are wrong its been accepted by a mod here that speed is kept at 100 m/s however radius, this case is called a tetherball
As usual, you have no idea what you are talking about. You must specify whether you are actively reeling in the cable (this is what Galileo assumed in his response to your vaguely worded question) or just letting it wrap around a pole (like the tetherball case). These are different scenarios with different answers.
Stick to one scenario and get it straight. Stop posting the same thing over and over.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
