Where Is the Center of Mass in a Plate with an Off-Center Hole?
To find the center of mass of a uniform circular plate with an off-center hole, the problem involves using subtraction rather than integration. The center of the larger circle is at point C, while the center of the hole is at point C', located 0.80R from C. The approach suggests treating the cut-out hole as a negative mass disc superimposed on the original plate. This method simplifies the calculation by allowing the use of basic principles of mass distribution. The final position of the center of mass can be expressed in terms of R, as indicated in the hints provided.
sweatband
A uniform circular plate of radius 2R has a circular hole of radius R cut out of it. The center C' of the smaller circle is a distance 0.80R from the center C of the larger circle. What is the position of the center of mass of the plate?
Hints:
subtraction is to be used
answer expressed in terms of R
I believe integration is required to solve this, but I do not know where to begin.
If anyone knows of a link they could send me that could lead me in the right direction, please let me know!
On the other hand, I believe, if you know that centre of mass of a circle is at its centre, you do NOT need to worry about integration: addition (or, 'subtraction' as the hint says) will suffice!
HINT: The portion that has been cut out, you can assume that a disc of negative mass was superimposed in that portion! (Of course, of same magnitude of uniform mass density as the first one.)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
