Which stress counts when looking at yield
  • Thread starter Thread starter wahaj
    Stress Yield
When analyzing yield at the fixed end of a beam subjected to shear, bending, and torsional stresses, it's important to use Mohr's circle to combine these stresses effectively. Simply adding the magnitudes of different stress types is not valid unless they act in the same direction. The maximum stress occurs when shear is zero, and vice versa, so each should be evaluated individually against yield stress. The von-Mises yield criterion can also be applied to determine equivalent stress for complex loading conditions. This approach ensures a comprehensive assessment of yield potential in the beam.
wahaj
To makes things simple, consider a simple beam fixed at one end an a load applied at the other. This load will produce shear stress, bending stress, and torsional stress. When looking at yield at the fixed end, do I take the biggest stress of the three or do I add their magnitudes to see if it exceeds the yield stress of the beam? Also what do I do if I have shear and bending in 2 directions?
If you have multiple stresses to sort out, the best thing to do is use Mohr's circle to combine them. Bending stresses usually act in the axial direction; shear stresses can occur in different planes. In general, you cannot simply add the magnitudes of stresses together unless they act in the same direction.
http://en.wikipedia.org/wiki/Mohr's_circle
I thought I could add them using vector addition. If I remember my Mohr's circle correctly, on the circle the maximum stress occurs when shear is 0 and max shear is when stress is 0. So after drawing the circle and finding the maximum stress and shear I look at them individually to see if either exceeds the yield stress, which I assume is different in normal and shearing conditions. Is my reasoning correct?
I had completely forgotten about that. That should solve my problem, thank you for helping.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
