Why Are Phases in a 3-Phase AC Generator Separated by 120 Degrees?
  • Thread starter Thread starter jearls74
    Generator Phase
The discussion revolves around the phase separation in a 3-phase AC generator, specifically addressing why the phases are typically separated by 120 degrees and how this relates to the participant's design, which features phases that are 15 degrees apart. The conversation includes questions about the electrical and mechanical aspects of phase separation, as well as the configuration of the generator's windings.
  • One participant questions the standard separation of phases by 120 degrees, noting their design has phases 15 degrees apart and seeks clarification on this discrepancy.
  • Another participant suggests that the phases in the design are electrically 120 degrees apart, despite the mechanical separation being different, and explains the relationship between mechanical cycles and electrical cycles.
  • A participant expresses uncertainty about the configuration of phase 2 being in reverse and seeks further details about the windings and their connections.
  • One participant describes how the voltage peaks relate to the position of coils in relation to the magnetic field, indicating that the 120-degree phase separation can be understood through a simplified model of coils and a moving magnet.
  • Another participant indicates that the original description of the design may be incorrect or taken out of context, suggesting that phases should be evenly spaced in a correctly wired alternator.
  • The original poster acknowledges confusion about the electrical versus mechanical separation of phases and requests a detailed explanation.
  • The original poster revises their sine wave chart and seeks feedback on its accuracy.
Participants express differing views on the phase separation in the original poster's design, with some asserting that the phases should be evenly spaced while others explore the implications of the design's specific configuration. The discussion remains unresolved regarding the correctness of the original poster's setup and the implications of the phase separation.
There are limitations in the clarity of the original poster's design details, including assumptions about the windings and their connections. The discussion also highlights the dependence on definitions of electrical versus mechanical phase separation, which remains a point of contention.
jearls74
Hi everyone, i have a question or two about the phases of a 3 phase A.C. generator. I have read about and seen several sine wave charts that state the phases are separated by 120 degrees, can someone explain this? i know the obvious that a circle is 360 degrees and that divided by 3 equals 120 degrees, but in my design the phases are 15 degrees apart. I am using a 8 magnet design ( following the rule there are one pair of magnets for every 3 coils ). The plotted results on a sine wave chart i drew give me 3 positive peaks followed by 3 negative peaks and repeats 3 more times for one revolution ( 4 voltage cycles per revolution). How does 120 degrees come into play? and my second question is: why is phase 2 connected in reverse? I will include a drawing of the stator so you can get an idea of what I am talking about on the 15 degrees apart. Can anyone shed a little light on this?
Im not sure about phase 2 being in reverse, but, to answer your question about the phases being 120 degrees apart. In your design they ARE 120 degrees apart, but only electrically. One cycle of ac electricity is going from 0v then swinging positive, negative, then 0 again. So for one mechanical cycle of your alternator, you have four electrical cycles. Your design is actually quite common in power generation plants to get the required 50 or 60Hz at a reasonably low generator shaft speed (they wouldn't last nearly as long if they had to spin at 3600 rpm)
I'd need to see some more details but what you describe sounds either wrong or you are quoting out of the context. In a correctly wired alternator the phases should be even spaced.
Here is a drawing of the stator and magnets
And . . . . .?
It looks ok. Did I miss something?
Where are the windings and how are they connected. Is there a picture of the waveforms you refer to?
Im reworking my wave form chart, ill try to post it tomorrow, as for the windings, I am not that good at detailed drawing. Wouldnt all the 1's be i set of windings and all the 2's be the second and so on? Have i assumed wrong? The 3 phases would be connected in the delta set up. I also don't follow on how the phases are electrically separated by 120 degrees, i understand the mechanically they are separated by 120 degrees. if this could be explained in detail i would appreciate it. Also, thanks for the replies famousken and sophiecentaur.
The phase of the volts on each coil relates to its position in the rotation wrt the magnetic field. If you had three coils lined up, side by side, on a bench and moved a magnet past them, the voltage peaks would occur one after the other
Now consider an alternator with just three coils and a bar magnet rotating inside. Not necessarily efficient but it would give you a feel for what goes on as the magnet sweeps past each coil. The 120 degree relative phases from each coil would follow pretty logically from that setup.
I reworked my sine wave chart and found out what i was doing wrong. Does this look right?
  • · Replies 27 ·
