Why Aren't My Methanol Flames Changing Colors with Different Salts?
  • Thread starter Thread starter vaselinessa
    Methanol
The discussion focuses on achieving colored flames using methanol and various salts, specifically strontium chloride and boric acid. Users report that while strontium chloride produces intermittent red flames, boric acid initially burns green but shifts to yellow. The primary issue arises from the inability of sodium chloride (NaCl) and potassium chloride (KCl) to dissolve in methanol, resulting in a clear/blue flame. The solution involves dissolving salts in water before mixing with methanol, with a recommended ratio of 75% methanol to 25% salt solution for optimal results.
  • Understanding of flame chemistry and color production
  • Knowledge of solubility principles for salts in solvents
  • Familiarity with alcohol types, specifically methanol, isopropyl alcohol, and ethanol
  • Basic laboratory safety and handling of flammable substances
  • Research the solubility of various salts in methanol and water
  • Explore the chemistry behind flame color production with different metal salts
  • Experiment with varying ratios of salt solutions to methanol for enhanced flame colors
  • Investigate alternative alcohols that can be used for flame coloration
Chemistry enthusiasts, educators conducting flame tests, and hobbyists interested in pyrotechnics or visual demonstrations involving colored flames.
vaselinessa
I'm trying to get a variety of colored flames by dissolving salt and methanol (after the fashion of this YouTube video et al.: http://www.youtube.com/watch?v=eRNLqTfIjQo").
I'm doing halfway alright with strontium chloride solution and boric acid solution, but having some trouble: the boric acid solution burns green for a little while but then turns yellow; the strontium solution is a bit dodgy, giving only intermittent red flames. Both solutions bubble and hiss: the boric acid solution hisses when the flame is yellow; the strontium solution hisses all the way through.
Worse, I'm not having luck with sodium chloride or potassium chloride or cupric chloride.
Regarding NaCl and KCl, I can't really get either to dissolve in methanol. As a consequence, I just get the clear/blue methanol flame, not yellow nor purple. Anyone have any advice?
As for cupric chloride, I get a green flame, not the blue one from the video (starts out looking rather green, seems pretty blue after a little while).
Chemistry news on Phys.org
That's because NaCl and KCl don't dissolve in methanol. In fact none of the salts used in that video dissolve in methanol. What he did was that he dissolved them in water first then he added enough methanol so that the solution would ignite and sustain a flame.
Just dissolve the salts in water then add methanol. I'd recommend trying 75% methanol and 25% salt solution. If the colors aren't bright enough increase the ratio of the salt solution to methanol. You just need enough methanol to ignite the solution. It doesn't have to be methanol by the way; it can be isopropyl alcohol or ethanol. Any alcohol that mixes with water will suffice.
Good to know. I'm trying what you suggested. Hit or miss so far.
9K
15K
25K
