Why can Hawking Radiation not work in reverse?
Hawking radiation cannot work in reverse because while black holes can lose energy through vacuum fluctuations, they cannot gain energy from antiparticles, as antiparticles have positive energy. The surrounding space cannot lose energy by the emission of a negative-energy antiparticle, as this concept conflicts with the principles of energy conservation. Energy is relative, and the vacuum around a black hole has non-zero energy due to its gravitational field, allowing for particle-antiparticle pair creation. Additionally, placing a black hole in a warm heat bath can lead to an increase in its mass, as radiation flows into it. The discussion highlights the complexities of energy interactions in the context of black holes and Hawking radiation.
rollcast
I understand that to obey conservation that the black hole must lose energy and mass and the surrounding space must gain an equal amount of energy and mass.
Then why can the antiparticle not be emitted from the black hole, adding negative energy and mass to the surrounding space, and the other particle goes to the singularity and adds positive energy and mass to the black hole?
Surely this still obeys conservation as the surrounding space appears to lose energy and mass, by the addition of negative energy and mass, and the black hole will gain an equal amount of energy and mass?
Thanks
AL
Astronomy news on Phys.org
From the end of
http://www.physics.ucdavis.edu/Text/Carlip.html#Hawkrad.
Note that this doesn't work in the other direction -- you can't have the positive-energy particle cross the horizon and leaves the negative- energy particle stranded outside, since a negative-energy particle can't continue to exist outside the horizon for a time longer than h/E. So the black hole can lose energy to vacuum fluctuations, but it can't gain energy.
Antiparticle != negative energy. Any antiparticle is going to have positive energy.
Also energy is not absolute but relative to something. The vacuum around a black hole has non-zero energy due to the gravitational field and the field can generate particle/anti-particle pairs with the one of the pairs falling into the event horizon.
I'm not sure that I agree with Carlip's explanation. Frequencies don't have a sign, and antimatter always has positive energy.
Also Hawking radiation can work in reverse. If you put a black hole in a warm heat bath, you are increasing the "zero level" of the space around it, and then you cause radiation to flow into the black hole making it bigger.
Twofish, isn't that happening with pretty much all black holes by absorbing the CMB?
Hi,
Can you clarify what you mean't by "zero level" above. Is it temperature relative to the BH ?
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
