Why Can't Brass Rods Be Charged by Rubbing?
Brass rods cannot be charged by rubbing because they are conductors, allowing electric charges to move freely across their surface. In contrast, polythene is an insulator, which retains the charge when rubbed. When a conductor like brass is rubbed, any charge that might be generated is quickly dissipated. Therefore, brass does not accumulate a static charge in the same way that insulating materials do. Understanding the difference between conductors and insulators is crucial for grasping electrostatic charging principles.
perjogab
Hey guys, I have a physics exam tomorrow. I found a question that I can't solve.
Rubbing a polythene rod with a cloth makes the polythene negatively charged but rubbing a brass rod in this way will not charge it. Why can't the brass rod be charged this way?
Thanks
Would you consider brass to be a conductor or an insulator?
Brass is a conductor isn't it?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
