Why Do My Outlets Have a Positive, Negative, and Ground?
Electrical outlets in homes consist of a hot wire, a neutral wire, and a ground wire. The hot wire carries 120V AC, while the neutral wire completes the circuit, ensuring safe operation. The ground wire is essential for safety, as it should not carry current under normal conditions and protects against electrical shocks. Ground Fault Circuit Interrupters (GFCIs) enhance safety by cutting off power if they detect an imbalance between hot and neutral currents. Double-insulated devices may not require a ground due to their design, isolating electrical components from the user.
Peter Pan
Just curios. Why do the electrical outlets in my home have a positive, negative, and a ground? With circuits that I am familiar with, if you have a positive and a negative connected, there is no need for a ground. Does anyone have an explanation?
Pan
Actually, your house has a "Hot" a "Neutral" and a ground wire.
The hot is fed 120V AC and since we need a complete circuit the neutral is used to complete the circuit.
The big difference between neutral and ground is that ground should never have any current on it and is therefore safe to hook to the outside case of electrical devices to use as a means to protect people from shocks.
In fact, if you look at a GFCI (Ground Fault Circuit Interrupter) that will be on any outlet near water (kitchen, bathroom, or outside outlets) there is circuitry that will open the circuit breaker if it senses ANY difference in the current on the hot and neutral wires. Since they are the two parts of the circuit, any current not flowing the complete loop must be going somewhere else (like in the bathtub) so therefore it interrupts the circuit well before enough current flows to trip the breaker by heating it, which may never happen even though a very unsafe condition may exist.
So we need the ground to be really safe. The exception is double-insulated equipment which uses only the two plug lugs of hot and neutral and the safety is provided by the design of the device. For example, a double insulated drill may have a metal drill chuck but it is completely isolated from the eletrcial circuit with electrical insulation.
Cliff
does the nutrual wire go back to the circut breaker to complete the circut?
It does not go to the breaker itself, but it goes to the neutral bar in the panel. If you own your own place, take the cover off and have a look.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
