FredGarvin said:
* Technical engineering term for high temperature.[/size]
Thanks for the thorough analysis, Fred. Some of those things never crossed my mind at all.
(I should explain at this point that I 'invented' this thing about 30 years ago to power a mach 8 fighter/bomber that I also 'invented' for an SF novel which will never see daylight. It was intended to operate at 28,000° C, so could actually plasmacize ram air for thrust rather than relying upon the onboard hydrogen supply. The whole thing, of course, depended upon a fictional amorphous al/ti/polyurothane alloy with a failure temperature of 30,000°.
There was no combustion chamber; rather it used a 'thrust block' of the same material perforated like the core of a NERVA, heated by a 10MW neutral hydrogen accelerator, through which the propellant flowed.
The compressor was to be driven by a hugely powerful electric motor drawing from a pair of SNAP generators, later replaced by a 20MW cobalt 60 beta-source generator. It didn't feed to the engine, but to a gas separation system that pulled the hydrogen out and sent it to the fuel storage. The engine turbopump drew from that. There was no oxydizer, because it worked by pure thermal expansion.
All that I'm trying to do now is 'downgrade' the idea to see if it could be done with actual technology.)
I'm concerned about the aerodynamics of the intake ducting, since it can't be properly efficient for both configurations. I figure to maximize it for ram mode, since the compressor can compensate somewhat for bad flow in turbo mode.
The thermal soakback never crossed my mind, and I haven't a clue what to do about it other than either routing the fuel or other coolant around the compressor, or just putting it a lot farther away from the combustion chamber.
The different operating characteristics with different oxydizers also didn't occur to me. I'd have a pretty good idea of how to deal with it in an IC engine, by fiddling with the mixture and timing, but I really don't know nearly enough about rockets or jets to have clue in this case.
I just noticed while referring back to your post that Gaming Addict has weighed in while I was composing this. I'll just go ahead and post this, then read that one.
