Why Does More Vapour Form When Taking a Bath in Colder Weather?
More vapor appears when taking a bath in colder weather due to the condensation of water vapor in the cold air. Colder air holds less moisture, causing the steam from the bath to condense and become visible. Although warmer air can hold more water vapor, the visible steam observed in colder conditions is primarily due to condensation rather than increased evaporation. The perception of more vapor in colder weather may stem from the contrast between the warm bath and the cool air, making the steam more noticeable. Overall, the temperature difference significantly influences the evaporation and condensation processes.
avito009
When the temperature in a city is lower and one has a bath in the bathroom then why does more vapour get created? More vapour than it would be created when the temperature is higher?
Maybe it doesn't? Perhaps you see more steam (ie. condensed water vapour) because the air is colder and the water vapour from the bath consenses in the cold air.
But maybe it does! When the air is colder, the amount of water vapour it can have is less. (Which is why it condenses, as above.) But if the air gets warmed by the bath water then it becomes capable of holding more water vapour. So maybe more bathwater can evaporate then?
Since water vapour is invisible and the amount of water which evaporates is too small to notice as a fall in liquid level, my guess is the first case. You are noticing more condensed water vapour (colloquially, "steam") in the cold air and thinking that is water vapour. When the air is warm, the water evaporates, becomes invisible and you never see it again! So you don't realize there was lots of water vapour.
Likes BvU
Check out the water vapour thread . The temperature difference is a factor in the evaporation rate.
(In your case the 'containing volume' isn't closed).
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
