Why does the E-field inside a cylinder =0?
  • Thread starter Thread starter lodovico
    Cylinder E-field
The electric field (E) inside a long, thin-walled metal tube carrying a surface charge density (λ) is zero for any point within the radius (R) of the tube. For points outside the tube (r > R), the electric field is given by the formula E = λ / (2πrε0). This conclusion is based on the principle that the electric field inside a closed conductor, devoid of internal charges, remains zero due to the inability of field lines to penetrate the conductor.
  • Understanding of electrostatics and electric fields
  • Familiarity with Gauss's Law
  • Knowledge of surface charge density (λ)
  • Basic calculus for integrating electric fields
  • Study Gauss's Law and its applications in electrostatics
  • Learn about electric fields in conductors and their properties
  • Explore the concept of surface charge density and its effects on electric fields
  • Investigate the behavior of electric fields in cylindrical geometries
Students of physics, particularly those studying electromagnetism, as well as educators and anyone seeking to understand the behavior of electric fields in conductive materials.
lodovico
Figure 24-32 shows a section of a long, thin-walled metal tube of radius R, carrying a charge per unit length  on its surface. Derive expressions for E in terms of distance R from the tube axis, considering both (a) r > R and (b) r < R. Plot your results for the r = 0 to r = 5cm, assuming that  λ= 2*10^-8
C=m//and R = 3cm
[i can't put the figure since the question is in the book]
q = ε0 ∫ E dA
i got the answer to (a) E=λ/2∏rε0
i don't understand why (b) is 0
urgent help due tomorrow
You know that field inside a closed conductor, with no internal charges, is 0. You can think of this as being because field lines cannot pass through it. This tube is 'long'; as long as you are not near the ends, any field reaching in from outside will be small.
  • · Replies 16 ·
