Why doesn't (P1xV1)/T1 = (P2xV2)/T2 work here?
  • Thread starter Thread starter eurekameh
    Work
The discussion centers on the application of the ideal gas law, specifically the equation (P1 x V1)/T1 = (P2 x V2)/T2, in a scenario involving R-134a in a rigid container. The initial conditions include 10 kg of R-134a at -40 degrees Celsius, with the container heated to a pressure of 200 kPa. The calculated final temperature is 66.3 degrees Celsius, and the initial pressure is 51.25 kPa, derived from thermodynamic property tables. The equation fails because R-134a does not behave as an ideal gas under these conditions, particularly due to phase changes and non-ideal behavior at varying temperatures and pressures. Understanding the limitations of the ideal gas law is crucial when dealing with real gases like R-134a in thermodynamic processes.
eurekameh
10 kg of R-134a fill a 1.348 m^3 rigid container at an initial temperature of -40 degrees Celsius. The container is then heated until the pressure is 200 kPa. Determine the final temperature and the initial pressure.
I found the final temperature to be 66.3 degrees Celsius and the initial pressure to be 51.25 kPa using thermodynamic property tables. However, when I plugged all of the values into the equation (P1 x V1)/T1 = (P2xV2)/T2, it does not work. Can anyone explain why?
Would you expect it to behave as an ideal gas over that temperature range?
ahh. i see. thanks =)
