Why is a Return Wire Necessary in Electrical Distribution?
  • Thread starter Thread starter physicspriya
    Distribution Wires
The discussion revolves around the necessity of a return wire in electrical distribution systems, particularly focusing on its role in forming a closed loop for current flow. Participants explore the implications of this setup in both theoretical and practical contexts, including high-power transmission and the behavior of current and voltage in circuits.
  • Homework-related
  • One participant questions the purpose of the return wire, asking if it carries current or simply forms a closed loop.
  • Another participant asserts that the return wire is necessary because current flows through it, implying its functional importance in the system.
  • A participant introduces the concept of three-phase power transmission, suggesting that multiple wires are used in high-power applications.
  • There is a follow-up inquiry about whether the return wire carries the same amount of current as the outgoing wire, indicating a desire for detailed explanation.
  • A later reply references Kirchhoff's law, stating that the sum of currents at a node is zero, and discusses the relationship between current, voltage, and power consumption at the load.
Participants express differing views on the specifics of current flow in the return wire and its relationship to the outgoing wire. While some agree on the necessity of the return wire, the details regarding current equality and the implications of Kirchhoff's law remain contested.
Participants mention the speed of voltage and current waveform propagation, suggesting that the length of the wire loop or transmission line may influence the answers to their questions. However, this aspect is not fully explored or resolved.
Electrical engineering students, educators, and professionals interested in electrical distribution systems and circuit theory may find this discussion relevant.
physicspriya
i m an electrical student. can anybody clearly tell me why is a return wire provided from the generating plant to the load? does current flow through the return wire or is it simply meant to form a closed lop?
The wire is provided because current flows through it, of course. If it had no function, it would seem a bit odd to spend so much money building it.
- Warren
so the concept of closed loop is met.Now my next question is does the return wire carry the same amount of current as the go wire?please explain this in detail. Thanks for responding to the previous question
Thread moved to Homework Help. physicspriya, what do you think? What has your reading about electricity told you so far about your question?
Keep in mind that the propagation of the voltage and current waveforms will happen at a significant fraction of the speed of light, so the answer to your question will depend on how long the wire loop or transmission line is... Can you tell us why?
Your question I believe is about voltage and current. Kirchoff law states that the sum of currents going into and from a point/node is zero. The current flowing to the load and away from the load will be completely the same. However loads consume power so if the current is the same then the voltage much reduce. The power transferred is due to the voltage drop at the load. For electricity to flow - there must be a ring or loop to and from the source.
  • · Replies 16 ·
  • · Replies 236 ·
13K
  • · Replies 20 ·
