Twinfun2
- 32
- 0
chroot said:This worries me. Pin #3 is the output pin, which supplies current to the load. If nothing is connected to it, it should be floating, and will probably not go all the way down to 0V. If you've connected pin #3 to your LED and resistor, it should have a voltage of around 4-5V on it.
If pin #3 is really all the way down at ground (0V), then a huge amount of current is likely flowing out of it. Something's screwed up with that pin. Disconnect everything from it, and make absolutely sure there's no continuity between it and the ground rail.
- Warren
The way I was told to do it was to disconnect the timer, and place wires where the pins would be, and to read those wires compared to a ground with a multimeter.
