Why Is the Mixed SU(2) Term Invariant in Scalar Multiplet Models?
The discussion centers on the invariance of the mixed SU(2) term in scalar multiplet models, specifically the term $$\Phi^\dagger T^a \Phi \ \Psi^\dagger t^a \Psi$$. This term remains invariant under SU(2) transformations due to the properties of the adjoint representation. When the scalar multiplets ##\Phi## and ##\Psi## undergo transformations, the adjoint representations can be expressed in terms of the original terms in the Lagrangian, leading to the conclusion that the invariance holds as shown through the algebraic manipulations involving the generators ##T^a## and ##t^a##.
  • Understanding of SU(2) group theory and its representations
  • Familiarity with scalar multiplet models in quantum field theory
  • Knowledge of Lagrangian formalism and potential terms
  • Proficiency in algebraic manipulation of group transformations
  • Study the properties of adjoint representations in SU(2) group theory
  • Learn about scalar multiplet models in quantum field theory
  • Explore the derivation of invariance in Lagrangian terms under symmetry transformations
  • Investigate the role of SU(2) generators in particle physics
The discussion is beneficial for theoretical physicists, particularly those specializing in quantum field theory, particle physics, and symmetry principles in models involving scalar multiplets.
Ramtin123
Consider two arbitrary scalar multiplets ##\Phi## and ##\Psi## invariant under ##SU(2)\times U(1)##. When writing the potential for this model, in addition to the usual terms like ##\Phi^\dagger \Phi + (\Phi^\dagger \Phi)^2##, I often see in the literature, less usual terms like:
$$\Phi^\dagger T^a \Phi \ \Psi^\dagger t^a \Psi $$
where ##T^a## and ##t^a## are SU(2) generators in different representations.
See for an example eqn (4) in this paper
I am wondering why the above term is invariant under an SU(2) transformation?
Any helps or comments would be appreciated.
PS: I was told that after a transformation of the form ##\Phi \to U \Phi## and similarly ##\Psi \to u \Psi##, we get:
$$\Phi ^\dagger T^a \Phi \to \Phi ^\dagger U^{-1} T^a U \Phi = ad(U)_b^a \ \Phi ^\dagger T^b \Phi$$
and similarly, for the term involving ##\Psi##. where ##ad(U)## is the adjoint representation of SU(2).
But I cannot work out how to eliminate the adjoint representations in the above expression to get back to the original term in the Lagrangian.
This is the scalar product of the two adjoint vectors
[tex]V_{a} \equiv \Psi^{\dagger}T_{a}\Psi, \ \ \mbox{and} \ \ v_{a} \equiv \psi^{\dagger}t_{a}\psi[/tex]
Now, if [tex]\Psi \to U(\alpha) \Psi = e^{-i\alpha^{a}T_{a}}\Psi,[/tex][tex]\psi \to u(\alpha)\psi = e^{-i\alpha^{a}t_{a}}\psi,[/tex] then [tex]V_{a}v_{a} \to \Psi^{\dagger} \left( U^{-1}T_{a}U \right)\Psi \ \psi^{\dagger}\left( u^{-1}t_{a}u\right) \psi.[/tex] Now, if you expand [itex]U^{-1}, U, u^{-1}[/itex] and [itex]u[/itex] and use the algebra, you find [tex]U^{-1}(\alpha)T_{a}U(\alpha) = D_{ab}(\alpha)T_{b},[/tex][tex]u^{-1}(\alpha)t_{a}u(\alpha) = D_{ac}(\alpha)t_{c},[/tex] where [tex]D_{bc}(\alpha) = \left( e^{-i\alpha^{a}J_{a}}\right)_{bc} = D_{cb}(- \alpha),[/tex] and [tex](J_{a})_{bc} = - i \epsilon_{abc}.[/tex] So, if you substitute these, you find [tex]V_{a}v_{a} \to D_{ab}(\alpha)D_{ac}(\alpha)V_{b}v_{c} = \left( D(- \alpha)D(\alpha)\right)_{bc} V_{b}v_{c} = \delta_{bc}V_{b}v_{c} = V_{c}v_{c}.[/tex]
  • · Replies 27 ·
  • · Replies 38 ·
  • · Replies 0 ·
