Why is the transition in resistance gradual at the Critical Temperature
The discussion revolves around the gradual transition in electrical resistance observed at the Critical Temperature (T0) in superconductors. Participants explore the underlying reasons for this phenomenon, considering factors related to material properties and temperature variations.
  • One participant notes that different regions within the superconductor may not reach the critical temperature simultaneously.
  • Another participant draws an analogy to uneven heating of mashed potatoes in a microwave, suggesting that similar unevenness occurs during cooling.
  • A further contribution highlights that the quality of the superconducting material affects the steepness of the transition, with purer and more uniform materials exhibiting a narrower transition range.
Participants present multiple viewpoints regarding the gradual transition, with no consensus reached on a single explanation. The discussion remains open to various interpretations of the phenomenon.
The discussion does not resolve the assumptions regarding the uniformity of temperature across the superconductor or the specific definitions of material quality affecting the transition.
thanasis
Hello. The measurement of electrical resistance as a function of the superconductor's temperature yields fundamental insights into its properties. The Critical Temperature, Critical Current Density, and the Critical Magnetic Field, can all be obtained through variations of a basic experiment.
I would like to ask you. Why is the transition in resistance gradual at the Critical Temperature (T0) on plot of resistance versus temperature ? ( see the attached picture ). Thank you !
The different regions in the superconductor aren't reaching critical temp at the same time.
any help please ?
Like when you heat mashed potatoes in the microwave. They don't heat evenly right away. The same thing happens when you try to cool objects too.
It also has to do with the quality of the superconducting film/material. The Tc of a superconductor depends on how uniform and pure the material is, meaning how steep the transition is will largely depend the quality: a "bad" film will always have a wide transition. This is one reason why the width of the transition is often used as a figure of merit when reporting on the quality of e.g. high-Tc materials.
  • · Replies 0 ·
