Why the Electric field outside 3 infinite boards is 0?
axcelenator
1. Three boards are in the x axis. the middle one is in x=0 and charged in a positive sign density is: σ. the other 2 boards are in : x=d and x=-2d. This 2 boards are grounded.
The question is why outside the boards the ElecField is 0?
I though that i don't waste energy to bring an electric charge from x=∞ to x=d because the potential in ∞ is 0 (from my theoretical assumption - but in the question nobody told me that).
So, what is the best answer for that? Thanks!
I think, yours is the best answer! Those plates are grounded, that is, they are at the same potential as infinity. No work is done when a charge moves from infinity to those plates, so the electric force (-negative gradient of the potential energy) has to be zero.
Of course, it would not be true if there were charges outside the grounded plates.
ehild
Another question about that: I found that on the middle plate the charge is divided in 2:1 ratio: The electric field from X=0 to X=d is:E1 = (8/3)*pi*k*σ
and from X=0 to X=-2d is: E2 = (-4/3)*pi*k*σ.
If I want to find the total force on the middle plat should I do: F=σ*(E1-E2) ??
Thanks
It is all right but you can simplify the result you got for E1, E2, and F.
ehild
Sorry, it is half of that: F=σ*(E1-E2)/2
See for example: http://web.mit.edu/8.02t/www/materials/StudyGuide/guide04.pdf
The charge does not act on itself, and half the electric field between the plates is due to the charges on the middle plate.
You can also derive it from the energy of the electric field between the plates. The energy density is U=1/2ε0E2. If the middle plate is moved by dx, the electric field does work, and that is equal to Fdx. At the same time, this work of the field will decrease the energy. The change of energy is equal to the work done.
ehild
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
