Why Use z Instead of r for Dipole Moment Calculation?
The discussion centers on calculating the dipole moment of a spherical shell with a charge distribution defined as σ = kcosθ. The integral for the dipole moment, P = ∫r σ dζ, yields zero when using the position vector r directly. The solution manual suggests using the z-component, Rcosθ, instead of r due to the symmetry of the charge distribution, which simplifies the calculation. The confusion arises from treating the unit vector \hat{r} as constant, while it is actually dependent on the angles θ and φ in spherical coordinates.
  • Understanding of dipole moment calculations in electrodynamics
  • Familiarity with spherical coordinates and their integration
  • Knowledge of vector calculus, particularly in the context of electromagnetism
  • Ability to convert between spherical and Cartesian coordinates
  • Study the derivation of dipole moments in Griffith's "Introduction to Electrodynamics"
  • Learn about vector integration techniques in spherical coordinates
  • Explore symmetry considerations in charge distributions
  • Practice converting integrals from spherical to Cartesian coordinates
Students of electrodynamics, physicists working on electromagnetic theory, and anyone involved in advanced calculus or vector analysis.
Idoubt
I'm trying to do problem 3.28 in griffith's electrodynamics. The problem statement is, to find the dipole moment of a spherical shell with charge distribution σ = kcosθ
The way I tried to do it was to use the definition of dipole moment, which griffith defines as
P= ∫r σ dζ
where r = position of charge w.r.t origin ( in this case R ) and dζ is volume element.
The above integral gives 0 ( unless i did something stupid)
I looked up the solution manual and the way it does it is to use Rcosθ ie z instead of r. Can some1 explain why this is?
You should consider r in the integral as a vector. and since the charge distribution has symmetry with respect to x and y axes, we only consider z component of r which is Rcosθ. You can check x and y and make sure that they are zero.
I see now. My problem was that even though I looked at it as a vector, I didn't realize that the unit vector \hat{r} itself was a function of θ and \phi and I took it out of the integral. When i rewrite it in cartesian co-ordinates and do the integral for each component ( cartesian unit vectors are constant so I can take it out of the integral ) it comes out fine. But when I look at this, vector integration with spherical co-ordinates seems very complicated, is there an easier way than rewriting in cartesian co-ords and integrating?
i got confused with this problem too, thank you for taking it out. :smile:
:smile:
