Will an induction cooker work in reverse if a hot pan is place on the coil?
An induction cooker does not work in reverse when a hot pan is placed on the coil. The primary mechanism of heat generation in induction cooking relies on electromagnetic induction, which requires a magnetic field generated by the induction coil. A hot pan, while capable of transferring heat to the coil through conduction, does not produce a magnetic field necessary for electromagnetic induction, resulting in minimal energy transfer and primarily infrared radiation.
  • Understanding of electromagnetic induction principles
  • Knowledge of heat transfer methods: conduction, convection, and radiation
  • Familiarity with induction cooking technology
  • Basic physics concepts related to magnetic fields
  • Research the principles of electromagnetic induction in cooking appliances
  • Explore the differences between induction cooking and traditional cooking methods
  • Learn about heat transfer mechanisms in materials
  • Investigate the design and functionality of induction cooktops
Engineers, appliance designers, and anyone interested in the science of cooking technology will benefit from this discussion.
matt6770
I was wondering whether an induction hob cooker would work in reverse if a hot pan is placed on the coil - so would this generate a current? I would assume not as the heat induction pan wouldn't be able to create a magnetic field in the coil?
You are correct...the hot pan can heat the coil, mostly via conduction, but alas a hot object won't usually produce electromagnetic induction...just a little infrared radiation...
Yes shame it would be cool. Thanks for the response.
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 60 ·
  • · Replies 43 ·
