Will Cast Iron dissolve in dil. or conc. acid?
The discussion focuses on determining the percentage purity of iron in cast iron using redox titration. The initial step involves reducing iron to Fe2+ by reacting cast iron with sulfuric acid. Participants confirm that both concentrated and dilute sulfuric acid can produce iron(II) sulfate (FeSO4), but recommend using dilute acid to avoid the production of sulfur dioxide gas. There is a suggestion to use hydrochloric acid (HCl) instead, to prevent oxidation, but concerns are raised about potential interference from chloride ions during titration with permanganate (MnO4-). The conversation also touches on the dissolution of impurities in cast iron when using dilute acid, indicating a need for further clarification on how these impurities behave in the reaction.
dfx
Hi,
I have searched rigorously for a solution to this problem but I seem to get inconclusive answers. I want to find the percentage purity of iron in cast iron and the best way to go about this is a redox titration. The first step is to reduce the Iron to Fe2+ . I intend to do this by reacting it with Sulphuric Acid and forming FeSO4. The only thing is, will cast iron react with dilute sulphuric acid (<1M) or does it require concentrated acid (>1M)? I know with conc. acid the resulting products are FeSO4 + SO2 + H2O and just FeSO4 + H2 with dilute acid. Any advice/feedback would be much appreciated.
Chemistry news on Phys.org
Well, technically, that would be Oxidation to Fe+2.
LEO GER Loose Electrons Oxidation, Gain Electrons Reduction.
Cast Iron should react with both concentrated and dilute Sulfuric acid to produce an aqueous solution of Iron (II) Sulfate.
Since both conc. and dil. H2SO4 will produce FeSO4 (aq) which is what your aiming for, you might as well use dilute since you will not have to deal with the Sulfur Dioxide gas being produced in the reaction.
I would rather try to dissolve iron in HCl, avoiding oxidation at all. Even then Fe2+ solutions tend to get oxidized with air oxygen so just before titration you should add some SnCl2 to reduce Fe3+ to Fe2+, then some HgCl2 to remove excess Sn2+:
SnCl2 + 2HgCl2 -> SnCl4 + Hg2Cl2
(note Hg2Cl2 is weakly soluble and doesn't interfere during manganometric titration).
Check details in some handook, I am sure Vogel should list some methods.
[/url]
Hello, thank you for your reply. That is a great addition which will score valuable marks. My only problem with using HCl is that after oxidation to Fe2+ I intend to titrate against MnO4- thus oxidizing further to Fe3+. Won't Cl- from the HCl interfere as it is a reducing agent?
Ah yes my bad it is oxidizing.. posted in a hurry! Thank you very much I'm glad that's sorted. What about the impurities in cast iron will they also dissolve in dilute acid?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
