Will Karan stop in time before hitting the skunk? Physics chase problem help!
  • Thread starter Thread starter 7282
    Physics
Karan is driving at 90 km/h and spots a skunk 60 meters ahead, taking 0.25 seconds to react before decelerating at -5.00 m/s². The skunk crosses a 5.00-meter wide road at 0.70 m/s. To determine if Karan stops in time or hits the skunk, the problem requires calculating the time it takes for both Karan and the skunk to reach their respective positions. The initial step involves converting speeds to the SI system and applying kinematic equations. The discussion concludes with the user successfully solving the problem after receiving guidance.
7282
Hi, I'm having a lot of difficulty with my physics homework. I'd really appreciate it if someone would help me out here :D
Karan is driving at 90 km/h on a straight road at night, when she sees a skunk cross the road 60.0m ahead of this car. It takes him 0.25s to react before he puts on the brakes and decelerates at -5.00m/s2. Meanwhile, the skunk obliviously walks across the 5.00m wide road at 0.70 m/s. Calculate whether
a) Karan stops in time before she hits the skunk
b) the skunk crosses the road before Karan get there; or
c) Karan squishes the skunk
I've just been given basic kinematics equations.
With variables v, d, t, a
I'm not sure how to start answering this question.
The obvious first step is to convert all into SI system i.e km/hr to m/s..etc
from here there is a 2 way approach..
go with karan or skunk
for karan...
find time taken to reach at 60meter from origin
then use time to find whether the skunk manages to crosses
if skunk just reaches then it is crushed
if skunk dosent reach then karan is faster
if skunk reaches and travels more then it reaches faster
for skunk...
find time taken to cross the road
then compute whether karan travels less than 60 m or more in given time
if more then karan crosses first
if less then skunk passes first
if equal then god save the skunk
here it is assumed that karan travels along opp edge of 5.00 m wide road from where skunk starts walking
hope it helps
for karan...
for skunk...
hope it helps
Thanks a lot it did help managed to solve the question :D I'm not sure if its right but yea!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
